Easily select and colour components in batches in browser
5 REPLIES 5
jasonUJ2XR
192 Views, 5 Replies
I'm building my assembly by importing parts in groups (designing lights), and I want to colour code each group type:
ie:
1 - Luminaire body parts
  Body-XX-A
  Body-XX-B
  etc
2- Luminaire Optics
  Lens-XX-A
  Lens-Holder-XX-A
  etc
3 - Electrical components
  POWERSUPPLY-XX-A
  LED CONTROLLER-XX-A
  etc
As I drag each component into my model, I want to colour-code that component to its particular "group" (ie- all the "Luminaire Body parts" to be blue, all the "luminaire optics" to be green, etc....
But I have to right click each component after inserting it, and do the CYCLE COMPONENT COLOUR COMMAND.
Sometimes it takes 10 or more times to do this command to come around to the colour I need, and even then the colour might not be the exact colour as the others (slightly different), see attached image showing slightly different colours...I wasn't able to get the component colours to match exactly , even after cycling through all the colours multiple times....
How can I batch select and batch change component colours, so I'm choosing multiple components (all in the same "group"), and change all of their colours EASILY to be the same colour, especially without doing the command multiple times....?
5 REPLIES 5
g-andresen
in reply to: jasonUJ2XR
Component colors cannot be selected individually.
günther
jhackney1972
You can create a Selection Set of all your components and assign an Appearance as a group using the selection set.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
TrippyLighting
in reply to: g-andresen
günther
I think you have to elaborate o that a little. In Fusion, appearance materials can be assigned at face, body or component level. Appearances of inserted designs can be overridden.
g-andresen
in reply to: TrippyLighting
The article from @jasonUJ2XR was about CYCLE COMPONENT COLOUR COMMAND.
I also believe that users should individually select the labeling of the components in the browser and in the timeline regardless of the appearance.
günther
TrippyLighting
günther
Gahh! Yes, of course! My bad!
