DWG\DXF export from Rhino, settings.
HughesTooling
Consultant Consultant
HughesTooling
I've made a custom export scheme for DWG\DXF to allow Rhino to export surfaces, meshes and curves, splines import as splines. On the export dialog click options and setup using the settings below.
Here's a screen grab of the export scheme I've set up in Rhino.
Mark
Edit. Updated info to include import of Meshes.
Mark Hughes
Owner, Hughes Tooling
pbreed
I was able to directly import Rhino 3dm files into Fusion....
If you can do that is there any need for DXF DWG rhino exports?
HughesTooling
The advantage to using DWG\DXF is you can import solids\surfaces and curves with 3dm you can only import solids\surfaces.
Mark
Mark Hughes
HughesTooling
Just an update on the advantages of using DWG\DXF, Fusion is now able in import Surface, Meshes and Curves in those formats.
Mark.
Mark Hughes
