03:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Wanted to get the best practice for building a 3D model where I know I'll be editing it in the future. What I have done is sketch the top then extruded to thickness then drew another sketch on a face on the side hoping that from there I could edit a dimension to change a part thickness. What I get is a driven dimension that will not edit.
So should the work flow been after the top sketch start a new plane and offset it to the edge of the part then dimension it then extrude from the top down to the side sketch? From there will it be parametric, just edit the side sketch?
Its a dummy part just trying to get my head around Fusion work flow.
