How to bevel
How to bevel
of18
Message 1 of 14
How to bevel
of18
Anyone know how to bevel the blue marked on the sketch? I´m a newbie, and I just can´t figure it out.stall.jpg
Replies (13)
Message 2 of 14
chrisplyler
I understand bevel to be synonymous with chamfer, and so am confused by your request to bevel an AREA instead of an EDGE. I'm happy to help if you will clarify.
Message 3 of 14
of18
Ok. I want to make a drawing for a guitar bridge (see pic) that I will cut out in a CNC router. [Image]
Message 4 of 14
Are you asking how to reduce the thickness of the blue, selected area, relative to the rest of the sketch? If so, you will want to hit 'E' for extrude, and type in a negative number equal to the thickness you wish to cut from the design.
Bevelling generally refers to a 100% stock thickness cut to produce a tapered edge. You could potentially bevel the line that you've drawn to make up that area, but you can't bevel the selected blue area.
Message 5 of 14
etfrench
If the surface is flat, then this screencast using a loft operation with a conic curve and a 3 point arc will create the blue area:
If the surface is convex, then create a sketch on the long side. Draw the bevel angle and enclose the area to be cut:
If it's something else, then you'll need to add more details.
ETFrench
Message 6 of 14
chrisplyler
Saying that it's a guitar bridge doesn't tell us what shape you're trying to achieve.
Message 7 of 14
laughingcreek
another approach
Message 8 of 14
of18
For some reason, the pic I attached, never showed up. I meant something like this.
Message 9 of 14
of18
Thanks.
I´ll see if I can figure this out.
Message 10 of 14
TrippyLighting
@laughingcreek's screencast covers how to do this. There are other ways to achieve this, but they all result in the same geometry.
If you're happy with his screencast ad it solves your problem then please accept his post as the solution (there's a button there for it.
Message 11 of 14
of18
Great!!
But... How did you start up with that convex shaped form? Thats exactly what I´d like to have
Message 12 of 14
chrisplyler
Message 13 of 14
docara
Look in the centre of the object in the screencast and there was a sketch of the required profile. This sketch was then extruded ( it looked like symmetrically).
I think you need to check some Fusion tutorials for the basics
MAtt
Message 14 of 14
of18
Awesome.
