Hi, I'm trying to model a caster like in the photo.
For example in this model that I found, the curvy part of plate consist of 7-8 part. I'm wondering is it possible to draw such pressed plates in one piece?(except holes and rivet)
Solved by jhackney1972. Go to Solution.
Real quick with estimated shape and dimensions. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
