Door panel help:-)
4 REPLIES 4
potlsnekkeri
220 Views, 4 Replies
Door panel help:-)
Hey, I'm going to make a panel for a wooden door.
how can i make that rectangle become a pyramid?
https://a360.co/3WW2Qtr
4 REPLIES 4
anoop9K98K
in reply to: potlsnekkeri
You can either use the loft function by creating a point at the particular you want it to be.
OR
You can you extrude function with taper angle
Give me a shout if you want me to show you.
Anoop
potlsnekkeri
yes can you show me
Hi @potlsnekkeri
As @anoop9K98K says, create a loft to a point.  here I created the point in the sketch where the rectangle is for the door. Create an offset plane, a new sketch, and project the point. use the point as the second side of your loft.Screenshot 2024-08-09 at 11.48.59 AM.png
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
CGBenner
@potlsnekkeri Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
