Distance & Angle Chamfer bug
O.Tan
Advisor Advisor
O.Tan
Rather then I create a thread for each possible bug, I decided to just compile all of them here instead.
https://screencast.autodesk.com/main/details/8def7f34-b479-4e33-8711-bbe6ddfe0f50
I just can't get all of them to be as what I drawn in the sketch, sure I can mirror the chamfer to do the work, but why can't I just select which side the distance 10, should be?
My suggestion is to add something like a flip button on the lines we chose, so if the program didn't get it right, the user can just click on the flip button and it'll technically be the correct orientation.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
jeff_strater
Thanks for bringing this up.  Yes, this is a limitation of the current Chamfer UI.  I agree that this would be a good area to improve Fusion.  I will make sure that this is on our list to fix.  At the same time, it would help me make the case if you could also put it into the Idea Station:  http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125 .  It helps, when we are prioritizing, to know that customers are actually encountering a specific problem.
Thanks!
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
O.Tan
Okay, already posted it in IdeaStation
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/distance-amp-angle-chamfer-bug-and-im...
Omar Tan
Malaysia
mikolaj.ilczyna
It's been 4 years now and this still hasn't been fixed. It's also broken when trying to mirror features containing two distances/distance+angle chamfers. Seriously, what the hell, this is a serious bug!
