disable the look at to origin feature
mac_ito
Message 1 of 20
mac_ito
Hi, how can I not have this original camera move when creating or modifying a sketch and using the look at feature?
Replies (19)
Message 2 of 20
jhackney1972
Setup and created a Named View that you want to use for your sketch before creating it.  Leave the "Auto Look at Sketch" off as you showed in your video.  Create your sketch, select the Named View from the Browser and you are ready to go.  Named Views ignore the origin and only use the view they are created for.
John Hackney, Retired
Message 3 of 20
mac_ito
thanks but i'm not going to create a nameview for each of the sketches i create, that's insane.
I just want the camera to stop pointing at the origin.
The look at feature alone does it well, why is its behavior different in the case of a sketch?
Message 4 of 20
jhackney1972
I certainly would not do a named view for every sketch but I use named views for groups of sketches in the same general area.  You do not have look at a view directly on to sketch accurately.
Message 5 of 20
mac_ito
Rather than finding alternatives one could also hope that the developers fix this problem.
"You do not have look at a view directly on to sketch accurately." or not 👇🏻
Message 6 of 20
HughesTooling
The reason given for this is the origin has a point so the zoom fits the only geometry in the sketch. You might find double clicking the middle mouse button will zoom to the model, not sure as I normally create my models around the origin anyway.
Another option is create a plane on the face and use that for your sketch. This will actually create more robust models as you can rereference the plane if it loses its reference and is way more robust than using "Redefine Sketch Plane" that usually destroys your design.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 20
mac_ito
the zoom should be on the surface/plane selected for creation.
the look at features should have one and the same behavior, regardless of the context in which it is used.
and creates additional steps to overcome this inconsistency, no
Message 8 of 20
g-andresen
I would like to point out that a plane is infinite even if it is related to a body surface.
günther
Message 9 of 20
mac_ito
Thanks for the tips, but that's not really the point.
Message 10 of 20
jeff_strater
@HughesTooling has it right.  Auto-look-at for a sketch zooms to show the whole sketch.  The origin point is a geometry in that sketch, so...  it should be included in the zoom to show the sketch contents.  This is unlikely to change, IMO.  Personally, I find auto-look-at to be the most annoying feature in all of Fusion, which is why I always disable it.  90% of the time, my sketches are aligned with one of the view cube's front/top/bottom view's anyway, so I use that.
Small Fusion history story:  I had to beg and threaten to even get auto-look-at to be added as a preference.  The original plan was to always do auto-look-at.  Can you imagine?  So, life could be significantly worse...
Jeff Strater
Engineering Director
Message 11 of 20
mac_ito
@jeff_strater, To orient the view cube I imagine you will click on it with the mouse pointer?
Message 12 of 20
mac_ito
or not because if it had been integrated as such from the start, we could have quickly noticed that its definition was not relevant, it would have been corrected to better meet the need and today we would not be having this conversation. Can you imagine?
Message 13 of 20
mac_ito
and we talk about this problem @Phil.E  , that’s my daily life..
Message 14 of 20
Phil.E
This is reported in the user story/improvement ticket FUS-58898 which aims to make Fusion perform a minimum translation to look at selected faces. A lot of work has gone into the investigation of this aspect of Look At. Implementing the change isn't always so straightforward. But we hear you and have been spending time on it.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 15 of 20
mac_ito
Hi
When will fusion be smart enough to zoom in on the area we defined and not stupidly zoom in on the origin when creating or modifying a sketch?
On a daily basis it's so painful. Please do something.
Message 16 of 20
g-andresen
take  a look at 3D-Connexion CAD Mouse > „Quick Zoom“
günther
Message 17 of 20
mac_ito
Thanks but quick zoom does a zoom not a look at, and then it would still be better if it was native and we were not forced to buy additional equipment to use such a basic function
Message 18 of 20
kontaktA44SC
please fix it. this is annoying !!!!!!!
Message 19 of 20
Phil.E
We still haven't fixed the 'zoom to origin' that happens when you "look at" a sketch with the look at command. However, there is a workflow that takes advantage of how Look at will look at faces correctly (just not sketches).
If you want to turn off the automatic Look At that happens when you create or edit a sketch, try this workflow:
  1. Turn off Auto Look At preference
Un tick this boxUn tick this box
2. When sketching, use the Look At command if you need to orthogonally look at a face, or the view cube if it lines up with the cube faces.
3. Use the Select Other menu to pick the face under the sketch profile while selecting the face to look at. This performs the minimum translation.
Video
I hope this helps.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 20 of 20
kontaktA44SC
been using fusion for quite a while and as far as i can remember there was a time when it worked fine (without any workarounds) - to whoever broke it i send my regards ...
