Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning everyone.
Attached I have a drawing of a roll former roller. These rollers wear out over time and need to be reconditioned, removing .02 or so each time.
So that means the OD of the roller will change each time this needs to be done. So my question is, is there a way to change only the root diameter (5.82 in this case) and all the dimensions will change with it accordingly? That way I only would have to edit one dimension each time we recondition, instead of going back and changing each one.
Any ideas?
Thanks in advance.
