How to fix a fixed joint at the both ends?
raviteja
Observer Observer
raviteja
Observer
Observer
Hello everyone,
I am designing a gas shock absorber. In that, I can't fix the shock absorber both ends with a joint command. can anyone help with that?
the actual plan is I need to simulate shock absorber with both sides fixed and with sliding mechanisms.
Thanks in advance
johnswetz1982
This is more of a design forum question. @seth.madore
etfrench
You will need three joints: A fixed joint at each end of the shock and a sliding or cylindrical joint between each section of the shock.
https://knowledge.autodesk.com/community/screencast/e7e75856-fdd6-4a07-baab-ce8d2ac9685e
p.s. Attach your file to the thread (File/Export/Archive file *.f3d) for more help.
e7e75856-fdd6-4a07-baab-ce8d2ac9685e,640,590
ETFrench
etfrench
Here's the screencast.
ETFrench
