Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Develop, or flatten, a curved surface to a sketch ?
Le_Bear
Message 1 of 14
Le_Bear
skerry--rylie-osmer_macarthur-brach-state-park-wpb-fl
There are plenty of tips around about projecting a sketch onto a curved surface, but how about the reverse? WITHOUT using sheet metal.
I guess the best example I could give is a stich and glue boat. Say that I model something like this, using mostly Loft for the hull.
How could I extrapolate the developed surfaces to get the exact shape to cut, like in this example below?
if this is doable in Fusion right now, I would love to know how. If not, could this be a feature to be implemented?
Thanks for suggestions,
Bernard
SKERRY_complete
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
Replies (13)
Message 2 of 14
TheCADWhisperer
I would split up into the individual Components.
For all of the developable sheets I would use Sheet Metal (doesn't matter if the material isn't sheet metal) to get the Flat Patterns.
For all of the double curvature components I would use a combination of MeshMixer and Fusion as follows (the video is for Inventor, but the process would be identical for Fusion).
In this case I am doing the Sail, but it could be for any of the components.
Message 3 of 14
TrippyLighting
Very nice screencast. Thanks for that! I very rarely work with triangulated meshes or Meshmixer and this ability of Meshmixer was unknown to me.
I
Message 4 of 14
Le_Bear
Thanks you for this very interesting screen cast, did not know this feature was in MeshMixer. Still, what I don't understand, is how would  I split each surface in a separate body or component, as originally it's a single body made by loft? The sail is obviously a single body to start with.
Maybe I am missing something obvious?
I do appreciate the help, and will refer to your screen cast in the future.
Bernard
Bernard Grosperrin
Message 5 of 14
TheCADWhisperer
@Le_Bear wrote:
..... how would  I split each surface in a separate body or component, ...
Message 6 of 14
Le_Bear
Yes, I know the feature, but never thought I could use the edges of a surface as profile. Hum, OK, I need to try that. Thanks!
Bernard Grosperrin
Message 7 of 14
Thank you very much for this screen cast. In a last two days a tired several methods to flatten or unwrap my small dingy hull design, non of them worked, but this one is working.
Message 8 of 14
pedro.tx
Community Visitor
Community Visitor
 Thank you. It’s so refreshing to see a clear and complete solution that I don’t have to search everywhere for. I will be sure to check out your channel!
Message 9 of 14
SLOW.PROCESS86
Observer
Observer
Sorry to bring up an old thread. Does anyone know if there's a way to take flat plans such as the ones posted above and then to form them into the completed boat?
Message 10 of 14
davebYYPCU
That would be the most counter productive way to do it.
Published plans I deal with are notoriously filled with errors, and making a model to unfold is a known reliable way to go.
Might help....
Message 11 of 14
TheCADWhisperer
@SLOW.PROCESS86 wrote:
....take flat plans s
Message 12 of 14
odolyte
Here's a quicker way to do this with F360 and Meshmixer. You'll get an .svg file.
https://www.youtube.com/watch?v=dalldQLphyo
Moebius Factory
Message 13 of 14
barry9UDQ6
I am very curious as to the recommendations for flat patterning the developable surfaces.
In Inventor I used to loft as a surface between 2 splines, then thicken and flat pattern, but I have yet to find a way to do this in Fusion unless I am missing something.
Message 14 of 14
TrippyLighting
No, you're not missing any functionality.
This can only be done in Fusion 360 with developable  surfaces/geometry with the sheet metal tools.
Flattening non developable surfaces will always result in some degree of UV-stretching.
