Designing shock absorber.
sanket223.patil
Message 1 of 10
sanket223.patil
Hello ,
I am designing a shock absorber . I have an downloaded one . But I want to make my self .
But dont know how to make spring , see the image provided . I know there is a function of coil , But the spring I am making has different diameter in middle and at ends its different . So how to make it .spring.JPG
Sanket Patil
Mechanical Engineering
Expert Elite
Accepted solutions (3)
Replies (9)
Message 2 of 10
davebYYPCU
You need some construction bodies,
front profile like an oval, is Patch > Revolve,
Then Patch > Sweep with Twist, a horizontal line, from axis to. Wider than oval, with pitch of twist.
Split Revolve Body with pitched twisted body.
Create 3d Sketch, Project > Include 3d Geometry, select Split body edge off the Revolve Body.
Hide Patch Bodies.
Create Model > Sweep, steel spring.
There is a YouTube video to cut the spring in one plane and Revolve joints on each segment, for a working Spring.
Might help...
Message 3 of 10
sanket223.patil
Thanks @davebYYPCU
Can you provide screencast , It will help me to understand more .
Sanket Patil
Expert Elite
Message 4 of 10
melvinbrian3d
Hide Patch Bodies.
Might help...
that's exactly... should work... i made a few springs weeks ago
MelvinBrian3D
Message 5 of 10
sanket223.patil
Hello @melvinbrian3d
Can you share a screencast with me .
I had also made springs , but cant figure out that diff. diameter thing .
Sanket Patil
Expert Elite
Message 6 of 10
melvinbrian3d
ok my friend... let me finish something, and i will share with you.
MelvinBrian3D
Message 7 of 10
TheCADWhisperer
@melvinbrian3d wrote:
.....ok my friend... let me finish something, and i will share with you.
The diameter AND the Pitch varies, be sure that your example includes the variable pitch to be a valid response to the Design Intent.
Message 8 of 10
melvinbrian3d
thanks for the advice... but for now i just made with differnt Diameter... ... @sanket223.patil tell if this work for you. i'm uploading the screencast.
MelvinBrian3D
Message 9 of 10
melvinbrian3d
Hello ,
here is my screencast as the post said... with different Diameter
MelvinBrian3D
Message 10 of 10
sanket223.patil
Thanks Alot @davebYYPCU @TheCADWhisperer @melvinbrian3d
I will try this out 🙂
Sanket Patil
Expert Elite
