Colored 2D Drawings
Colored 2D Drawings
Message 1 of 9
Colored 2D Drawings
Is there a way in Fusion 360 to export a model from the "3D environment" into the "2D drawing environment" while retaining its color appearance instead of converting to just black and white lines?
Replies (8)
Message 2 of 9
kris_berg
Hi @Anonymous,
I believe what you want are shaded views.  When creating a drawing view you can choose "Shaded" or "Shaded with hidden edges" outlined in red in the dialog image below. Let me know if this does not solve your problem.
Kris Berg
Senior Software Architect - Autodesk
Message 3 of 9
melvinbrian3d
that's very simple, in the DRAWING mode or 2D Drawing environment just double click on the model and change from Visible to Shaded.
MelvinBrian3D
Message 4 of 9
martin.konarsky
Hello everybody.
To use shaded view is for me not a solution.
I do not want to change colors in the model. I would like to keep model as it is and in the drawing highlight some lines, or dimensions, or make comments before export to pdf. Maybe add some circles, or rectangles, or remark clouds. I need to highlight different things(lines) for different supplier. I can not change complete model all the time.
Is there any way, or will be there any way one day?
Message 5 of 9
g-andresen
@martin.konarsky wrote:
Is there any way,
NO
Who knows?
take a look at the Roadmap
günther
Message 6 of 9
martin.konarsky
Thanks Gunther,
than I have to continue with AutoCAD........to finish or comment. Which is  a pity.
Message 7 of 9
... Assuming you love using Fusion360, right? ... You can just make 'the pieces of the 3D object' into black and white using Appearance(s) creating the effect by default.
So for example, for a patent submission you need a black and white 2D or 3D image, right? and if you are using Fusion360 they don't allow you to render your image that way. So to get around it, you can make your Fusion 360 image black and white using Appearance(s) (Hitting S, then A) highlighting the 'edges' you want in black and highlighting the 'surfaces' you want hidden in white -then you can print the image in black and white, and scan the printed image back to .pdf
Thank you,
Message 8 of 9
fschollenberger
Hey martin,
we also face the same problem. As we only wanted to highlight some of the modifications in the drawing with a red circle for our supplier, we made a simple work around, which might help at least a bit:
1) create a circle with desired color and thickness in adobe illustrator or similar programm
2) export it as png with transparent background
3) Insert the png in the fusion360 drawing
4) Drag it to the desired location
We inserted them also in the drawing-template we use daily. There we now have some of the basic shapes in different color to drag over the updated area which is important for our supplier.
Maybe this helps at a bit.
Best, fabian
Message 9 of 9
martin.konarsky
thanks
