Design appears in lines instead of metal solid
I am having a problem such that after I create a sketch and extrude it upwards, the design will appear in lines instead of a grey solid (as shown in the attachments). How do I convert the design back to grey solid?
Thank you.
jeff_strater
most likely, you are in "wireframe" mode.  You can change it here at the bottom of the screen:
"Shaded with Visible Edges Only" is the default
Jeff Strater
Engineering Director
Mr Muhammad
Press the Ctrl + 6
