Cylinder Layers
Cylinder Layers
maple15207
Message 1 of 43
Cylinder Layers
maple15207
I created a cylinder with many layers. I am trying to sketch a quadrilateral at the top, and extrude it to the bottom.
However, when I get out of sketch mode, the layers disappear. Any ideas why?
Replies (42)
Message 41 of 43
laughingcreek
@maple15207 wrote:
.... The only thing I need to change is the highlighted point by 5 degrees towards the z-axis. ....
no idea what changing the indicated point by 5 degrees toward the z axis would mean in this context.  do you mean make the diameter of the top smaller?  Anyway, clearly you're doing something different from me if what I did works and you're attempts don't.  hard to say what that would be with the given information.
maybe this will help.  attached is a video of me nodding around with various aspects  of the model.  perhaps this will spark further questions or understanding.
note, first thing I did was simplify the profile used to create the outside of the surface from the spline to an simple arc. (I just made the arc construction geometry.  this makes it easy to get back to the original).  I did this manly because computing between changes will be MUCH faster with the simple arc.  get the general shape you want here, then add the more complicated geometry back in.
Message 42 of 43
maple15207
looks like I got it.I think. If not I'll be back. 😉 Thanks so much!
Message 43 of 43
CGBenner
@maple15207
I'm glad you seem to be moving forward now.  If there were any specific suggestions in any of these posts that helped you, would you mind using Accept Solution on those, so that others might find them in the future?  Thank you!
Chris Benner
