I am trying to model and 3d print a toy rocket ship for a Christmas gift. I am using the the references below:
What makes this hard is rather than being smooth cone, it is a 12 sided shape that forms a cone.
My first idea was to create a series of construction planes on the Z axis every 5 mm and put inscribed polygons of the correct radius on each plane. Then I tried on using the Loft tool to combine them all together.
Attachment 1 is the construction planes, and attachment 2 is an example of what I was able to create.
The problem I am having with this is it is very tedious and the loft tool fills in between the shapes using paths that are not necessarily what I want.
Is there a better way to do this? Perhaps creating a curve (seen attachment 3) and only one polygon (centered at the origin) that I then extrude using the curve as the guide for the radius?
