@TrippyLighting @maple15207
You want to create a pot where each rib varies in height and these variations repeat around the pot in a spiral-like sequence, with a 12-degree offset between each column of ribs?
I like to look at things from different perspectives so:
To achieve the spiral ribbed design as in your original concept, first create the base pot using a Revolve command. Then, design 6 unique ribs of varying heights in the Form Workspace. Use the Circular Pattern Tool to replicate these ribs around the pot, setting the pattern axis to the pot's center and spacing them with a 12-degree offset. For the spiral effect, adjust the Z-offset or incrementally move the ribs upwards after applying the pattern. Ensure smooth transitions between ribs and the pot using Combine or Loft tools. Finally, export the model with high mesh resolution for accurate 3D printing results.
This is what you could do to try and make your design instead if struggling,
instead of "attempting" to get trippy to do it for you
Kind Regards
Ricky
