Cutting cube from sphere issue
surdu
surdu
Hello friends,
What I'm trying to achieve is cut a 180mm cube out of a 210mm sphere:
The preview looks great, as you can see, but as soon as I press Ok on that feature, the top part is missing:
Here is the above example file: https://a360.co/2MVwIBT
Am I missing something, or is this a bug?
Thank you!
JeromeBriot
It seems to be a bug. The missing part is always in the direction of the extrusion.
A workaround is to combine a sphere primitive with a box primitive.
surdu
Do I need to fill a bug somewhere to help fixing this faster, or posting it here will suffice?
JeromeBriot
AFAIK, the most efficient way to report a bug is to open a new thread in the Support forum with "Bug" in the title.
More info: Support Board Best Practices
But wait a couple of days. Maybe someone @Anonymous will read this thread.
JeromeBriot
And of course, you can also select New Body for the extrusion and next use the combine tool.
jeff_strater
yes, that is a bug.  Good catch.  I log it with the modeling team.  Very strange...
[edit]  the bug is FUS-58777
Jeff Strater
Engineering Director
