Cut operation and leaving a face uncut
javelin_exile
Message 1 of 11
javelin_exile
Hi Folks
This is a part derived from a supplier DXF that I was just modeling for cosmetic reasons. it has a feature where this hole goes completely through the part except for this tab in the circle that's supposed to interfere in the path of the hole. How can I achieve this?
Replies (10)
Message 2 of 11
shahriarsifat1802164
To make sure that the middle part not to be cut, you can use the offset command.
At first, make the circle visible, then select offset distance.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 3 of 11
javelin_exile
ahh yes except the piece to be left intact is at an angle and the offset would overlap it to get the material on the other of the tab side cut. The only thing I think I can think to do is cut it then fill it back in on the tab part in another operation.
Message 4 of 11
ritste20
Cut the hole through the first side up to the tab, then just make a new sketch on the face beginning the cut after the tab. Project your circle and finish the extruded cut through the rest of the part.
Or using the same sketch for the second extrude cut change your start plane to "from object" and pick the face to start the second cut beyond the tab.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 5 of 11
TheCADWhisperer
Message 6 of 11
javelin_exile
Yes, and the problem is the piece that needs to be left untouched is at an angle across the void so no matter which direction you come from the path of the cut touches the part I wanted to be left alone. I ended up just making a sketch and filling the hole after the cut operation. Another thing I thought of was just to make a tool body to extract from the model. I'll post the model below so you can see.
Message 7 of 11
javelin_exile
Sure here you go. if you remove the last extrude from the timeline you'll see the hole left by the cut operation.
Message 8 of 11
ritste20
Change extrude8 cut extent "to object" and select the angled face of the tab. Then you don't have to fill the cut after the fact.
Steve Ritter
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 9 of 11
javelin_exile
That's awesome. I never tried that, had it in my head it only works at right angles.
Message 10 of 11
ritste20
That feature can have issues with curved surfaces if the sketch profile does not fully intersect the face you select but generally can be used with any planar surface regardless of orientation in space. Definitely, a tool worth sticking in your back pocket for situations such as this where putting in an arbitrary extrude distance will leave your model less parametrically robust and not as capable to deal with changes to the geometry.
I'm glad this solved your issue.
Steve Ritter
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 11 of 11
Here you can see,
RUET
Thank you.
