Step export not using appearance settings
Message 1 of 9
When exporting a STEP file I'm getting a number of components being exported without their appearance textures applied. This started happening after I applied physical material properties. I have tried to reapply the appearance but it doesn't take. This is causing issues with our manufacturing partners. Please help.
I have attached screenshots of the same part when vied from Fusion and E-Drawings. I get the same result using my PCB layout tool (Cadence Allegro).
Replies (8)
Message 2 of 9
shahriarsifat1802164
You can have a try to make the model convert into .iges or .obj file rather than .step file.
I think this will help you to get a proper appearance there.
 Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 3 of 9
Sadly our layout tool requires STEP rather than IGES. For months I've been exporting files without issue.
Message 4 of 9
g-andresen
have a look at this thread
günther
Message 5 of 9
TrippyLighting
Hmmm... would you have an example file that exhibits that behavior?
I just tested this briefly with 2 components and a red/blue base color and an image-based texture on the top face of the red box and after re-importing the exported STEP into Fusion the colors and the texture both show up.
Message 6 of 9
@TrippyLighting  Thanks for doing that. I've attached one of the problem assemblies. Fingers crossed you can replicate the issue!
Message 7 of 9
TrippyLighting
I do see the same issue (missing textures), but I am not entirely sure yet why.
It will take me some time to investigate.
@Anonymous did anything change in the STEP export code recently?
Message 8 of 9
That's good news. I was worried that once exported it would all work fine.
Message 9 of 9
@TrippyLighting@jodom  Were you able to find a fix or a workaround for this issue
