Creating Documentation - Issue with Screen Captures in Fusion
JDMather
Consultant Consultant
Message 1 of 8
JDMather
@brianrepp
I create a lot of documentation for Word docs and Powerpoint.
I generally use Snag-it or simply Windows Print Screen or Alt+Print Screen.
So the normal workflow is to drill down in the Ribbon to desired tool that I wish to demonstrate and hit Print Screen.
Trouble is, in Fusion I immediately loose the desired focus and do not get captured screen image.
I used to be able to do this and it works with all other software.
Has something changed with Fusion that causes this workflow to no longer work?
(we are exclusively Window OS)
Replies (7)
Message 2 of 8
Beyondforce
Hi @JDMather.
I use FastStone Screen Capture, it's perfect!
http://www.faststone.org/FSCaptureDetail.htm
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 8
JDMather
Can you post an example image of a Fusion in Windows drop down from ribbon?
Message 4 of 8
Beyondforce
I will as soon as I get home.
Ben Korez
| YouTube
Message 5 of 8
PhilProcarioJr
@JDMather
Here is an example from FastStone: (The really Nice thing is no need to crop anything...just select what you want to capture and it does all the grunt work)
@Beyondforce is correct it is a very nice screen cap app. I have been using it for a while...
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 6 of 8
JDMather
Well, at least I see that  you are able to get a screen capture.
We will not be able to install additional software in computer labs, so now I just need to figure out why Snag-it or even Print Screen is not working when it used to work.
BTW - small world, I grew up in Minerva and Alliance. Oldest sister lives in Canton. Are you old enough to remember Clarkins Carousel.  That was our trip to the "big city".   Smiley Wink
Message 7 of 8
PhilProcarioJr
@JDMather
I don't think your problem is with Fusion as you can see here I just did a Ctrl-Print Screen and captured the expanded ribbon toolbar.
"BTW - small world, I grew up in Minerva and Alliance. Oldest sister lives in Canton. Are you old enough to remember Clarkins Carousel.  That was our trip to the "big city".   Smiley Wink"
Indeed it is a small world. Unfortunately yes I am old enough to remember them...Smiley LOL You grew up about 10 min away from me.
Phil Procario Jr.
Message 8 of 8
TheCADWhisperer
OK, I solved my problem with Snagit.
I had the hotkey set as PrintScreen, changed it to another key and the new key works with Snagit and PrintScreen works with Windows clipboard.
Interesting though, that the only program I had issue with was Fusion.
