Create Triangular Retainer Tab
I have two parallel, vertical components that stick up and will retain a horizontal bar.
I would like to place triangular retainer tabs at the top of both vertical components, facing inwards towards each other, in order to allow easy insertion and retaining of the horizontal bar. It would be the blue portion below (side-view).
Can someone please explain how to add this?
  • Tab
dsouzasujay
Hi @Anonymous ,
Please follow below video.
https://knowledge.autodesk.com/community/screencast/1343e29c-2f51-469f-a603-83159160c27d
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
jeff_strater
something like this:
Jeff Strater
Engineering Director
Thank you both! That helps a lot!
