Create surface from two splines and a closed sketch
glmeadows
Message 1 of 14
glmeadows
Is it possible to create a curved surface from two splines and the closed sketch shown below?
Replies (13)
Message 2 of 14
wersy
Message 3 of 14
TheCADWhisperer
@glmeadows
There is a better way.
I recommend:
Message 4 of 14
glmeadows
i'm sort of new to fusion so what is an f3d file
Message 5 of 14
glmeadows
Looks great but how did you do it?
Message 6 of 14
TheCADWhisperer
Message 7 of 14
glmeadows
Here it is...
Message 8 of 14
TheCADWhisperer
@glmeadows
You should always strive to fully define your sketches.
A bit more work because you have splines, but as I start to add missing dimensions the geometry is currently at unexpected sizes.
Message 9 of 14
glmeadows
sorry, i think this is what you want
Message 10 of 14
TheCADWhisperer
@glmeadows
I would use as few points as possible in a Spline.
I was able to closely replicate your Spline with only 3 points.
The best Spline might only have 2 points.
Blue curves should keep you awake at night.
Message 11 of 14
wersy
I loft only the half.
Then mirror it.
Message 12 of 14
johnsonshiue
Hi! Here is a solution close to your design intent (but not 100% correct) by using Revolve and Non-Uniform Scale. The resultant geometry is very smooth. You may convert it to Form for further tweaking.
Many thanks!
Software Test Engineer
Message 13 of 14
glmeadows
I just joined the forum and I'm new to Fusion but in my first post I'm amazed at all of the help I've received. Hopefully, someday I can help someone else.
Message 14 of 14
TrippyLighting
@glmeadows wrote:
i'm sort of new to fusion ...
There are a number of free tutorial courses Autodesk has created to help people learn the essentials.
My recommendation is that you start going through one or more of those, along with what you'll learn in this thread.
Lofting is an advanced topic I would not recommend for beginners.
@wersy has used a surface loft but has left out at least one curve. He had to because your sketch setup is incorrect in several aspects.
It is not adequately constrained or dimensioned, for example.
