How to bring objects flush with pivot on axis
jdaues
jdaues
Referring to the attached drawing, you see that body Roof3 needs to come down to be flush with body SouthRoofWall2. I can get it in the ballpark by rotate on the axis RoofAxis but that's fudging it of course.
How do I do this properly?
bwalker145
Using Modify -> Align on the two planar faces is the quickest with your current setup; see below.
I'd recommend converting your bodies into components though. This will allow you to use Joints to easily position & constrain the different features.
jdaues
Thanks for the tip about components. I didn't know about those. I selected all the Bodies, right clicked, and did Create Components from Bodies. Is that all I needed to do for that?
bwalker145
Yep, exactly. You can now use the "Joints" function between the different components to help align and constrain the parts, which helps create a robust parametric model. With Fusion, you really want to use Components when building assemblies. Think of it this way: Components are the individual parts, bodies are the geometry that make up the part. Just as an example, most of my simple designs *usually* end up with one body per component (although you may see multiple bodies in the timeline used to help build the final component design).
For a typical workflow of a simple assembly, you'll create an initial component and constrain it to the WCS. Then, as you build more components, you'll assemble (i.e. constrain) the different parts/components together with the Joints.
