fillet behavior on a curve
syltrand
Message 1 of 9
syltrand
On a flat curving surface, when I make a fillet the size I need, (in this example, 50mm), it leaves a sharp feature in the fillet.  This feature disapears when I make the fillet large enough.
How do I get a fillet that won't leave a sharp feature, and is the correct size?
edges to filletedges to filletshowing undesired featuresshowing undesired featuresshowing desired result (how do I get it to look like this, with the smaller fillet)showing desired result (how do I get it to look like this, with the smaller fillet)
Accepted solutions (3)
Replies (8)
Message 2 of 9
etfrench
Hard to say without the file. My first guess would be the outer circle isn't tangent to the center circle.
ETFrench
Message 3 of 9
TheCADWhisperer
@syltrand
Message 4 of 9
syltrand
Here's the file.  Still not sure what's causing this.
(didn't expect a quick reply, so, thanks!)
Message 5 of 9
TheCADWhisperer
@syltrand
See Attached.
Edit the fillet size and also add to the bottom.
Message 6 of 9
syltrand
Building the part your way works I guess.   I'll still see cursed fillets in my dreams though, hahaha.
Message 7 of 9
etfrench
It appears that splines behave differently than arcs:
ETFrench
Message 8 of 9
TrippyLighting
Yep, that "behavior" has been part of discussions a long time ago!
I consider that a bug, as other CAD systems do not behave this way.
@Phil.E
Message 9 of 9
Phil.E
You got it. FUS-186537
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
