Create drawing from design is broken
Hi i have a really big issue with drawings.
So i was trying to create a drawing from a custom view of my model. Did it many times before. But somehow after the latest update this feature is completely broken.I can't seem to get anything on the drawing board if i select a custom saved view.
Only the basic views like top, right, bottom show up correctly.
Furthermore i tried to get around it by moving the geometry manually in model view using one of the base views. This time the geometry lines showed up right but that's the only thing that was right, shaded mode doesnt work at all.
This is a major problem because i cant continue my work. Please help.
I'm using the latest version of Fusion 360 on a desktop PC with Windows 10
HughesTooling
I just tried a test with a named view and it works fine for me. Is the problem with just one design, are you seeing the same problem in older designs as well? Have you tried closing Fusion and reboot windows. If you still have the problem might be worth attaching diagnostic log files.
Mark
Mark Hughes
Owner, Hughes Tooling
