Tried every thing in the Fixes Available post. Hereis the output
Step 1
[GPU Information]
GPU Device: Intel(R) HD Graphics
GPU RAM: 64 MB (Integrated card)
GPU Driver API: DirectX 9.0
GPU Driver Verison: 9.17.10.4229
GPU Driver Date: 05/27/2015
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Notes]
1. If you have another discrete GPU on your system it is recommended to run Fusion on it to get better performance.
2. If you see any graphics display abnormalities, updating to the latest graphics card drivers could help resolve them; please check with your GPU vendors to download and install the latest graphics card drivers.
3. The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
On
Step 2
<?xml version="1.0" encoding="UTF-16"?>
-<OptionGroups>
-<BootstrapOptionsGroup UserName="Bootstrap" ToolTip="Special preferences that require the application to be restarted after a change." SchemaVersion="2">
<LastUserHubUrlWip UserName="LastUserHubUrlWip" Value="https://myhub.autodesk360.com/ue29af0bb"/>
<LastUserHubName UserName="LastUserHubName" Value="8597658976587"/>
<LastUserHubEdition UserName="LastUserHubEdition" Value="personal"/>
<LastUserHubUserRole UserName="LastUserHubUserRole" Value="ADMIN"/>
<LastUserHubUserId UserName="LastUserHubUserId" Value="ZHCNLTCGZ29F"/>
<LastUserHubHomeUrl UserName="LastUserHubHomeUrl" Value="https://login.autodesk360.com/login"/>
<ResolvedSidePanelUrl UserName="ResolvedSidePanelUrl" Value="https://ui-dls360.autodesk.com/dashboard/85/data_view_rel.html"/>
<MainWindowRectangle UserName="MainWindowRectangle" Value="-8,-8,1927,1087"/>
<LastDirectoryOptionId UserName="LastDirectoryOptionId" Value="C:/Users/Nathan/Google Drive/Nate MISC/Old CAD files/IGS Drawings"/>
<ReverseZoomDirection UserName="Reverse zoom direction" ToolTip="Reverse zoom direction" Value="1"/>
<MaintenanceStartTime UserName="MaintenanceStartTime" Value="1438574400"/>
<ShowGraphicsPerformanceMessage UserName="ShowGraphicsPerformanceMessage" Value="0"/>
<MaterialUIWindowRect UserName="MaterialUIWindowRect" Value="645,346,1495,876"/>
<MainWinMaximized UserName="MainWinMaximized" Value="1"/>
<ShowWhatsNewMessage UserName="ShowWhatsNewMessage" Value="0"/>
<driverOptionId UserName="Graphics driver" ToolTip="The driver used to display the graphics" Value="VirtualDeviceDx9"/>
<performanceModeId UserName="Limit effects to improve the performance" ToolTip="Automatically disable or degrade visual effects to improve the rendering performance; this will affect the display quality" Value="1"/>
