Continue groove along bend
swart79
Message 1 of 9
swart79
i am creating a bumper filler for my car but I fail to finish the drawing because i cannot continue the grooves along the bent part of the piece on the right hand side. on the flat surface i managed to use extrusion. But the curve is the problem for me.
See picture of drawing in attachment
Can you help, please?
Thank you very much!
Replies (8)
Message 2 of 9
HughesTooling
Can you export the design as an f3d and upload here?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
swart79
yes of course
see below
Message 4 of 9
wersy
You could use "Sweep"
Message 5 of 9
swart79
I tried that but when I do it it looks like this:
Message 6 of 9
swart79
for some reason you could select the whole profile (3 surfaces) but I can only select one.
Is that maybe the problem?
Message 7 of 9
swart79
I got it. I have to select the projection surface on the correct side.
Thank you!
Solved.
Message 8 of 9
jhackney1972
Please take a look at this web article about accepting solutions for your post.
John Hackney, Retired
Message 9 of 9
swart79
done for both of you. Thanks a lot!
