constructing a 3d sketch
ninolemann
ninolemann
Hello everybody,
i'd like to draw a 3D Sketch, along a certain path. (see attached picture)
the path should follow the surfaces of cylinders, almost like a helix (that i would do with the helix tool.
thing is, the bend changes direction mid-ways....
i can draw the 'shadows' of the sketch, just as in the attached picture.
- is there a way to turn parametric curves into splines?
- is there a way to project onto spheres?$
- can i do some path-rail-thing?
- has anyone ever done something similar? (most likely, i guess)
Help would be much appreciated.
Thanks in advance!
davebYYPCU
Check the file,
Made the path with two 2d sketches, (your shadows)
Create a 3d sketch,
Use Project > Intersection Curve, and starting at the uncommon end of the path,
select first portion of each curve, repeat as you walk along each curve, you are building a purple projected 3d curve in segments.
When you get to the end of sketch 3, there is still a short line in sketch 2,
Use Project > Include 3d Geometry, and select it.
Should works as a path.
For your questions,
- I don't think so.
- Yes, Project < Project to Surface, You need to be in an active 3d sketch.
- Yes, as above,
- Yes, used for rails in Loft, path for sweep, etc.
Might help...
