Message 1 of 12
Hello dear Fusion 360 community,
I have two holes drilled to the center of a cylinder, the holes are at different height and at different angles. Is there a way to make a cut between these holes so that the cut is always pointed at the center of the cylinder. I need a shape
that will simulate a mill path, as if a mill starts from 1 point and ends on the second point, on its way it is always pointed in the center of the cylinder and changes only the height and the angle.
