Change Parameters Help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I have been advised to use the Change Parameters menu item to setup user defined measurements for my project.
I have started this project where I have a plate that is 10mm thick. It will have other parts attached to it that may also be 10mm thick.
But I know that I may need to redesign the frame to different measurements, highly likely 6mm.
Some one suggested making User defined parameters with names that I can change in the Change Parameter area as this will save redrawing the whole project.
I carn't seem to understand how to make a user defined parameter.
Any help would be greatly appreciated.
I have attached the plate for the frame to this post if that helps.
Kind Regards
Ian
