Removal of Branch
Removal of Branch
Faraj_Monnapillai
Message 1 of 11
Removal of Branch
Faraj_Monnapillai
Is there any way to delete branch
Faraj Monnapillai
Replies (10)
Message 2 of 11
paul.clauss
Hi @Faraj_Monnapillai
Thanks for posting! Unfortunately, there is no way to delete a branch in Fusion 360 after it was created. This option was considered when branch and merge was being introduced (discussed here), but as the branch and merge preview will be closed it has not been actively developed. We apologize for any inconveniences this may cause you - all branches except the master branch will be removed when the preview of branch and merge is ended.
If you do have branches with data you would like to save when the branch and merge preview ends, one way to ensure that no data is lost is to create local archive copies of all the designs in the branch and then re-upload them to the master branch in your Fusion 360 Data Panel. This will create new copies of all the files from the branch and move them into the master.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Message 3 of 11
Faraj_Monnapillai
Thanks for that information.
I got one more question, is there any way rename a branch?
Faraj Monnapillai
Message 4 of 11
paul.clauss
Unfortunately there is also no way to rename a branch in Fusion - we apologize for this. This was discussed on this thread, but because the branch and merge preview will be ending, the change will not be made.
Paul Clauss
Message 5 of 11
Faraj_Monnapillai
Ok. thanks for the help
Faraj Monnapillai
Message 6 of 11
I have many many constructions on my account, some with brands.
what happens if branch and merge ends with them? do i get a pop up for every branch that i created to choose which to keep?
i dont hope ill loose some of those and notice this after a year
Message 7 of 11
paul.clauss
Hi @Anonymous
Thanks for posting! When the branch and merge preview ends, any data in an unmerged branch will be lost. The instructions to back up this data outside of the branch are below.
Before the Branch and Merge preview is fully ended, you will need to merge any branches that you would like to keep back to the master branch. If you cannot merge back to the master branch, you will need to create local copies of the files in the branch and re-upload them to the Data panel in a new project folder (not a branch) or copy the files in the branch you would like to maintain into a new project folder in Fusion 360. We apologize for any inconveniences this may cause.
I have attached a screenshot of the note in the preview preferences below:bam.png
Paul Clauss
Message 8 of 11
so i need to open all my ~1000 parts and check if i used a branch in them? or can you see it in the data panel?
so popup message with a list wich parts are being affected?
Message 9 of 11
charegb
I wanted to add some details to Paul's response.  As he said, our preferred workflow is for you to merge your changes to master but we understand that some customers have started using branches to create variations of a design so we need a way to keep all of the branches.
In one of the upcoming updates, we will offer a copy tool that will give you the ability to copy entire branches into subfolders of the project. So no branch data will be lost and you will be able to continue to work on it after its copied to the project.
Bankim
Message 10 of 11
so there will be a message for every branch?
because with so many parts i dont know anymore where i used this.
Message 11 of 11
paul.clauss
Hi @Anonymous
Thanks for the response! While I am unsure of what messaging the tool @charegb mentioned will include, it is easy to sort out the files that need to be backed up now - everything in a branch other than the master branch of a project will need to be backed up, as branches other than the master branch will be removed when the preview ends. You could use the instructions in my previous email to do so, but it may be easier to wait for the utility tool to be released.
You can find out if a project included branches by opening the top level of the project folders in your data panel and checking the branch dropdown as shown below:Screen Shot 2017-10-24 at 8.23.28 AM.pngI agree that it would be nice to see some messaging around this when the utility tool is released, but cannot comment on exactly how that tool will work as it is still being developed. We apologize for any inconveniences this may cause.
Paul Clauss
