Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all
trying to chamfer a hole on a sloped face.
if i select the rim of hole, it chamfers parallel to face. if i select wall of hole it does both sides, also parallel to face.
i need the chamfer to be parallel to the hole. if i use the hole tool it also does it parallel to face
is there an easy way to do this?
izzy
drawing attached is mockup showing 1 right and 2 wrong chamfers
