Chamfer not working?
2 REPLIES 2
happyday.mjohnson
720 Views, 2 Replies
happyday.mjohnson
I am trying to strengthen a lip on a an enclosure:
to look like this:
i've tried several different things, but i'm not getting the chamfer right.  I think it has to do with how i fillet'd?  Is there an easy way to do this?
Here is a link to my project  in case it is helpful.
Thank you.
to look like this:
Thank you.
2 REPLIES 2
PhilProcarioJr
@happyday.mjohnson
It's because you have a zero thickness edge between the top and bottom part. I would draw the chamfer on a sketch and use the sweep tool using the edge as a guide.
http://autode.sk/26r46mR
Phil Procario Jr.
Owner, Laser & CNC Creations
@happyday.mjohnson
Phil Procario Jr.
happyday.mjohnson
Wow!  This worked exceptionally well.  I am grateful for your thorough answer which included the example.  I appreciate the time you took to share your knowledge.  Thank you very much.
