I am trying to strengthen a lip on a an enclosure:
to look like this:
i've tried several different things, but i'm not getting the chamfer right. I think it has to do with how i fillet'd? Is there an easy way to do this?
Here is a link to my project in case it is helpful.
Thank you.
Solved by PhilProcarioJr. Go to Solution.
It's because you have a zero thickness edge between the top and bottom part. I would draw the chamfer on a sketch and use the sweep tool using the edge as a guide.
Phil Procario Jr.
Owner, Laser & CNC Creations
Wow! This worked exceptionally well. I am grateful for your thorough answer which included the example. I appreciate the time you took to share your knowledge. Thank you very much.
