We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Centering and Moving Multiple Sketches
Message 1 of 11
Hello Autodesk community! Appreciate all the knowledge I have learned from the community already.
I have searched the forums and the net but have not found out how to align a group of sketches. The problem is very straightforward, but I do not know the correct workflow. I have used the pattern to make a grid array of a circle, and want to align all 4 to the square. Coming from Illustrator / Cinema 4D, I would simply group them and align to the square, my target object. I can align one circle, but can I align a group of sketches to the middle?
A bonus extra credit for overachievers: After I extrude the circles to cylinders, can I merge the four cylinders bodies as one? When I say merge, I do not mean physically merge the objects, rather the bodies will be recognized as one unit.
I appreciate any suggestions!
Best regards,
Andrew
Replies (10)
Message 2 of 11
g-andresen
Please share your design.
This way it is easier to give hints.
1 way:
günther
Message 3 of 11
@g-andresen  Thank you, please see the link.
https://a360.co/2W1vV6V
Message 4 of 11
g-andresen
1. delete the 2 midpoint constraints
2. try it as shown in screenshot # 2
günther
Message 5 of 11
Thank you, but how can I delete the points when the sketch is locked? And why is it locked?
Message 6 of 11
g-andresen
you described the lock symbol.
This means > fully defined (not locked)   vs. pencil  not fully defined.
günther
Message 7 of 11
Can you tell me how to revert backed to editing it? I cannot delete any points. Thanks
Message 8 of 11
g-andresen
1. Double click on sketch or right click > edit
2. in this case : left click on triangle (midpoint constraint) > delete
günther
Message 9 of 11
JamieGilchrist
HI @Anonymous ,
I'll create a video and show you how'd I approach this.  You have to think about the problem a little differently than in Illustrator (20+ year user myself).  The power is in the mathematical formula Fusion uses to capture and maintain design intent. Yes, there are many approaches to what you're trying to accomplish, this is, but one.  video coming shortly...
Video:  Also attached the .f3d
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 10 of 11
Thank you!
Message 11 of 11
Thank you so much! And thanks for taking the time to make a video, very helpful!
Andrew
