how to make a twisted tube
Message 1 of 12
I want to make a round twisted tube ( like a 'wokkel"vorm ) like this:
I know how to make the round tube (and it has to be hollow) but I can not find how to make the spiral (wokkel= dutch) shape.
Can anybody help me?
Thank you a lot.
Marina
Replies (11)
Message 2 of 12
g-andresen
Hi Marina,
try it this way:
günther
Message 3 of 12
Thank you Gunther for your idea.
But what I reallu mean is this:
Message 4 of 12
g-andresen
what stopped you from showing it in the first post?
But maybe you can play around with this:
günther
Message 5 of 12
dikshant.
Hello @Anonymous ! There are several ways to create twisted sections in Fusion. One is to sweep a profile around a coil's edge using a guide rail.
Here's a screencast of the process - https://autode.sk/326caz0
Hope it helps 😄
Message 6 of 12
g-andresen
one more:
günther
Message 7 of 12
Thank you for the clear video.
But what I mean is the right form but it has to be round like a circle and not straight.
So a twisted hollow tube, somthing like this but than it has to go round and closed like a circle:
It is hard to explain because I can not find the right picture, but I hope this will help you to understand.
Thanks again,
Marina
Message 8 of 12
g-andresen
If you use the file I attached in #2 and create the profiles as you like and use the appropriate options (twist) along the subcircle with the sweeptool to form a body, you have what you showed in the screenshots of your last post.
günther
Message 9 of 12
chrisplyler
I didn't make it hollow, but you can. Just change the profile to suit as desired.
https://knowledge.autodesk.com/community/screencast/a2db0609-5607-4faa-97fa-c4e8e96123cd
Message 10 of 12
TheCADWhisperer
@Anonymous wrote:
So a twisted hollow tube, something like this but than it has to go round and closed like a circle:
Something like this?
Message 11 of 12
g-andresen
Hi Marina,
 what are you doing here.
After you started the thread with a sample image, I and @dikshant. made 4 suggestions, some of them with an attached file. Your reaction was: ..., but.
I could not see from your contributions that you were really concerned with the proposals.
Now @chrisplyler and @TheCADWhisperer have added the variants 5 and 6.
Possibly more will follow.
I, for one, am participating in this Game no longer.
günther
Message 12 of 12
TheCADWhisperer
 No participation  🏆
for you.  🙄
