Cannot select edges of faces to create fillet
Message 1 of 8
I'm trying to round off some sharp edges on a design that I made in Tinkercad originally and I believe should be done with fillets. Whenever I select Fillets though I can't actually select any face or edge on my model. (The Select button in the Fillets tab is blue, in case this makes a difference.) I have checked the object is selectable so I know its not that.
Replies (7)
Message 2 of 8
TheCADWhisperer
Did you convert the mesh to a solid?
Message 3 of 8
File attached as requested
Message 4 of 8
jeff_strater
Tinkercad is a mesh modeler.  The result is a mesh body.  You can convert a mesh body to a solid body (see screencast), and it works on a simple model like this one.  More complex models won't probably work as well, but this should get you going.
Jeff Strater
Engineering Director
Message 5 of 8
HughesTooling
If you build using simple shapes in Tinkercad you can transfer to Fusion and end up with a solid model, not a mesh. See this post for some info.
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
That worked perfectly, thank you. Now I just have to figure out why its 10 times the size of the original model.
Message 7 of 8
TheCADWhisperer
@Anonymous
Do not Open directly.
Start a new Fusion file with correct units.
Insert rather than Open.
Message 8 of 8
jeff_strater
In addition to the excellent point that @HughesTooling made about the direct integration that exists between Tinkercad and Fusion (which I had forgotten all about...), there is one other method.  I think this one depends on the kind of license you have (I think I remember that this is not available in the Personal license).  But, if you have it, you can pretty easily convert this mesh body to a better-quality solid using the "prismatic" conversion.
Jeff Strater
