How to solve the following design problem?
firanman
firanman
Hello everybody,
I posted a question in a previous post (https://forums.autodesk.com/t5/fusion-360-design-validate/why-my-model-doesn-t-work-properly-in-prac...), and my problem was solved partially with the design provided by @HughesTooling . After running the new design with the CNC mill, I've got the following result:
The shape is fine, but there is still a small misalignment as I marked in the figure. Could you please help me to solve this problem? I don't know where this problem originated from. I have attached the .f3d file as well.
davebYYPCU
I can't see the problem being a Fusion problem,
a case of a lot of machine backlash, in the vertical direction.
Might help....
