cannot derive dimension
andy.c
andy.c
Ok . After three hours of searching forums I cannot find out why I cannot make a dimension a function of another in a sketch. If I start a new file and make sketch of a rectangle I can dimension, i.e., the horizontal side. When I dimension the vertical I can select the horizontal dimension and divide by 2. the vertical dimension is displayed as: d1/2. Life is good.
I open an existing file and create the same sketch. I repeat the process from above. When I select the horizontal dimension it is not accepted into the vertical dimension value box. I cannot make the vertical dimension a function of the horizontal dimension.
Why?
etfrench
It's not reproducible on my machine.  Attach both your files to the thread for analysis (From the File menu:Export|Archive file *.f3d.)
ETFrench
andy.c
here are the two files to compare. the titles are self explanatory.
TheCADWhisperer
Capture Design History
andy.c
That helps. Is this public knowledge? How would I search for this?
Thank you.
Andy
