- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am looking to create a circle between an ellipse and another circle, such that this middle circle is tangential to both the ellipse and the circle. Normally, if I just create a simple circle and a simple ellipse, this works fine. And if I create a simple offset ellipse, I can also add the tangential constraint to the new ellipse also.
However in my drawing something has happened to my offset ellipse to prevent it from being used as a tangential constraint target - can anyone help me understand what might have happened to get it in this state? Note that I have trimmed the offset ellipse and in my experiments with simple shapes I was sometimes able to reproduce this issue, but I can't work out a reliable way to reproduce it.
Note that I am able to select the original elliptical arc (at the top left of the picture) as a tangent target, but it's the blue offset one I really want to apply the constraint to.
I've shared the design here: https://a360.co/2KRWvLG (v4, I've moved on since then).
Edit: I have no idea why that shared URL doesn't show anything.
Edit2: I was able to use a fillet to create the effect I was after, but the question remains as to what had happened to the offset elliptical arc to prevent it being used with a tangent constraint whereas the original arc is usable.
