Can we P.L.E.A.S.E have a REAL Escape key functionality ?
TrippyLighting
Consultant Consultant
Message 1 of 24
TrippyLighting
Yet again, Fusion 360 is stalling doing something.
Pressing the ESC key isn't doing anything. Sometimes we have to wait endlessly and because Fusion 360 is rather slow in general even if it finally completes the action we've still often waited several minutes.
Pull the arrow a little to quickly when filleting the "right" geometry. Fusion 360 takes it's sweet time.
Mistype something you wait again. Tough!
3 Years ago the explanation was given than this is complicated. OK. Granted. This was three years ago.
By this time it is totally unacceptable that this still happens and is not fixed!.
Replies (23)
Message 21 of 24
wmhazzard
Escape key does not stop the fillet command for me. Here is a model to try out which was converted from a mesh.
Pick an edge to fillet and set a dimension, then hit Ctrl and "accidentally" select the converted face. Esc will not stop the fillet command.
I have done that several times in the past where I have accidentally selected a chained face instead of an edge. Escape would be very appreciated. Forcing Fusion to shut down is not an acceptable solution.
Message 22 of 24
jeff_strater
It could be that Fillet is one command where escape is not supported, I'll have to check when I get back to the office.  Or, there may be something else going on that is specific to face fillet that is different than edge fillet.
Jeff Strater
Engineering Director
Message 23 of 24
stiller.design
mostly when having more than 10 edges selected or long "chains" of fillets
Message 24 of 24
TheCADWhisperer
Here is an idea...
in Autodesk Inventor Professional many of the tools have a toggle to turn Preview OFF.
Perhaps the Fusion developers could walk across the hall and ask their Inventor teammates how it is done.
