Create solid body from sculp plane
hackbratenMTTKN
hackbratenMTTKN
Hi folks,
I'm pretty new to the entire free forming stuff.
Today, I wanted to attach a handle-shaped curve to an existing body.
As I can see, the curve that I created with the "Create Form" feature, I like a piece of "paper" but not a solid model. Therefore I cannot combine this handle-shape with the existing body.
Maybe this is the wrong approach but I hope someone can guide me to the way of success 🙂
Thanks in advance!
Paul
Marco.Takx
I think you are looking for the replace face command.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
TrippyLighting
There are two ways to do this.
1. as @Marco.Takx has already mentioned is replace face. In order for that to work, however, the wave shape cannot have that U-Shape. A curve is fine, but you are basically going to replace a flat face with the curved face of the wavy surface.
Also, you should put fillets at the end of the timeline. Tying these operations on already filleted geometry is not a good idea. Cosmetic fillets are secondary surfaces.
2. You create your handle in the patch workspace and then match the T-PSLIne edges to surface edges. Once done with the T-Spline it converts into a surface and then you can stitch the two.
In general this shape does not require attaching T-Spline geometry to a solid at all.
hackbratenMTTKN
Thanks for your answer.
What would the corresponding workflow be?
Don't use the "create shape" function but use the patch workspace?
In the patch workspace, I'm not able to create a plane with individual faces to push and pull the geometry, right?
Sorry, I'm failry new to anything that is not Modeling related 🙂
hackbratenMTTKN
Besically yes, but I'm getting an error there unfortunately
Marco.Takx
Is the upper face also selected? It looks like in the picture. I think thats the problem.
Marco Takx
TrippyLighting
The shape you wat to create determines what tools are best to use.
It's not wrong to use a T-Spline when the shape requires it. Maybe you can create the complete handle shape as a T-Spline. However, the front of your T-Spline looks flat so that can be better done with a Spline and split body command.
Or you want the front slightly curved. Then you can sweep a curved line along that spline and end up with a surface. You can then use that surface to split the body.
For example this wavy front face would be more difficult to create in the Path or Model environments, so I creates a T-Spline surface face and split a solid body with it.
Edit: Note that I applied fillets as the last step!
