Hello everyone. I posted a similar issue I think last week concerning issues with the combine tool for coincident edges, a wise gentleman told me to use the boundary fill tool. Alas, for a different part, I'm having a similar issue but with boundary fill instead.
I used loft to seal the holes and I was hoping Fusion would treat the object and lofts as a single solid object rather then a hollow object with the holes covered up, but I don't think it works that way. I tried using the solid loft to connect the two lofts on the top and bottom to create a solid body and tried using both solid bodies with boundary fill, but this also did not work because they were coincident edges. Just like on my previous post I cannot merge these two bodies together because they are coincident rather than intersecting.
I also cannot use boundary fill for one body and then use the other body in a different action because of the same issue: they are coincident instead of intersecting.
I think the fact that Fusion cannot work with coincident edges makes the program problematic for designing molds but that's another issue.
Any help would be appreciated, I apologize for having to come back here I don't like feeling like I'm filling the forum with trivial issues.
