- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello friends,
I've been fighting with this for most of two days, so please forgive me if I sound a little frustrated.
I'm trying to model a glass-baffle stair railing. I've modeled a stanchion (a vertical pole) that is screwed into the floor on the bottom stair. I've also modeled the glass grippy clips (which I’ve chosen to call Grabbers) that grab the glass/wood/whatever baffles that prevent (human) children from falling off the side of the staircase. For simplicity's sake, I have only included the most basic situation here: One stanchion. One clip. Put 'em together.
The stanchion is in ‘Stanchion-Redo - 20260216-180203.f3d’, and the glass grabber that I would like to attach to it is in ‘Grabbers - 20260216-180203.f3d’ (There are two grabber components in that file. One is for mounting to the stanchion, and the other is for mounting to a flat wall on the other side, but that’s not relevant to this problem.) I've flailed quite a bit. I really thought that by creating explicit Joint Origins within each independent component, that I’d removed all ambiguity from this, but it seems there’s something else that I’m missing.
If you look at the screen cap video I've attached, here’s what I’m doing (or at least what I think I’m doing):
- In the attach video, I start with an empty document. I've already saved it, but it's a brand new, virgin document.
- Next, I insert the stanchion from the second file.
- Then I insert the ‘grabber’ from the third file.
- After inserting the grabber, I move it away from the origin so that I can interact with the various UI on it.
- I make the bolt that holds the grabber to the stanchion invisible so that I can more easily click the joint origin that it was obscuring.
- Then I tried to build a joint between that joint origin and the joint origin on the stanchion. In other words, I'm trying to mount the grabber to the stanchion.
- Nothing seems to happen.
- OK, so I try another approach: I use the Align function to align the two components based on their joint origins.
- Initially, I'm thinking, oh, lovely. At least it's in the right place now. I'll just make an as-built joint.
- The motion preview for the as-built joint doesn't make any sense, but hey, I'll go on faith, and click OK.
- Everything still seems to be correctly aligned, but let's try to move the stanchion.
- …the grabber does not move with it, despite them supposedly being connected by a rigid joint.
I am completely baffled. Why doesn't this work like so many other joints I've made before? The ‘bigger problem’ is so much bigger than this, but if I can’t even get one Rigid Joint to work, then everything else is just a waste of effort. Anyone have any hot tips on a situation like this?
Thanks!
Ian
