Datum Target Symbols
rcollins50v
Message 1 of 13
rcollins50v
Hi all,
I assume there are no datum target symbols (GD&T) available for use in Fusion? Are these on any roadmap for implementation?
Replies (12)
Message 2 of 13
MoshiurRashid
Obviously, there is Datum target symbols. The whole GD&D functionality is included in Fusion drawing.
Here is a picture of it.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 3 of 13
rcollins50v
That is not a datum target symbol. That is a datum symbol. You can search for datum targets in 14.5 to see symbol and its use case.
Message 4 of 13
HyoCha
That is also what I need.
This is Datum targets.
We really need this ASAP.
Message 5 of 13
Christian_56
Dear Moshier Rashid
referring your answer in this  topic to a question from rcollnis50v @rcollins50v  from feb 2020 . He is right,  I also searching to this symbols. I find no  possibility  to  describe this fundamental issue in a technical drawing. For me point of view it is a technical standard  and a must  to have this symbol in the general  symbol library of form and positional tolerances.
It might no be a "rocket point" to implement this in a  professional program like FUSION 360 .
I would  be very glad to get an answer  form AUTODESK. Thanks a lot
Christian from Germany
Message 6 of 13
fredrik.lotto
What is the latest status of this feature? (Round datum targets)
It's still not available and a really basic function when it comes to GD&T.
Examples can be found in ISO 5459
We need it asap. Is there a known "fusion-workaround"?
Message 7 of 13
marcelo_mehlberg
Community Visitor
Community Visitor
Is there any news related to that? I also need to add Datum targets and as far as I have noticed there is still not implemented...
Message 8 of 13
jlarsonLP454
I need this too. Fusion should support ALL the ASME drawing standard symbols...
Message 9 of 13
johnpgerrity
This would be greatly appreciated! Please add it to the drawing tools! Thanks!
Message 10 of 13
marc_potvin7TDK8
Same for me. I hope datum targets as per ASME Y14.5 and ISO will be implemented soon...
Message 11 of 13
jlarsonLP454
Bump - I need to add datum targets to a drawing as well as hatched areas to show where they apply, and Fusion can do neither. This is basic functionality, please add it!
Message 12 of 13
scottprater
Have you guys considered using the "Sketch Symbol" feature at all? I've created a bunch of symbols that are part of my standard drawing template to fill in for stuff that Fusion doesn't currently have (like flag notes, "CF" symbol, etc.)
-Scott
Message 13 of 13
jlarsonLP454
Good suggestion Scott - it shouldn't be needed for standard symbols, but I used it to create the datum target symbol and it works OK, once I figured out that %%C creates the diameter symbol that I needed
