Can't extrude face with radius
jeje
Message 1 of 22
jeje
I'm new to Fusion...
I want to extrude a face which has a radius but when I select the extrude tool I can't select this face, the tool works with the other plane faces with no issue, is that normal and is there a workaround ?
Many thanks for your help !
Replies (21)
Message 2 of 22
evanp4509U4JZ
Not a pro by any means but I believe extrude only allows selection  of planar profiles. I think "offset face" from the modify menu is what will get this done.
Message 3 of 22
jeje
Thanks a lot for you reply.
Unfortunately offset face moves the all body, I guess my model is wrong...
I inserted a stl file and generated a body from it so that might be the issue.
I want to extrude only the curved face but don't want to modify the top and bottom angles.
Message 4 of 22
wersy
Look what happens using offset face.
Message 5 of 22
g-andresen
project the profile and create a new body
günther
Message 6 of 22
jeje
Thanks a lot for your reply !
I followed your video and created a new body, but this doesn't solve my issue, with the new body I still can't extrude the curved face ?
Message 7 of 22
g-andresen
please show a screenshot what you want to achieve
günther
Message 8 of 22
jeje
I can extrude plave face but can't do the same with the curved one.
Message 9 of 22
g-andresen
1. @evanp4509U4JZ  has already said that you can only extrude planar profiles.
2. from your screencast I can't see what the end result should be.
3. please create a screenshot and sketch the desired change
günther
Message 10 of 22
MRWakefield
I'm not sure I really understand what it is you want to achieve. Are either of these like your desired result?
or are you wanting to lengthen the part like this:
Or something else?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 11 of 22
jhackney1972
In the video I show you how to offset the curved surface using the Surface tools.  At the end of the video I remove the fillets, offset both surfaces and then join them back with the fillets.
John Hackney, Retired
Message 12 of 22
jeje
Thank you all for your fast and nice support and sorry if I haven't been clear enough.
My goal is to cut a small amount of the surface excluding the top and bottom borders to be able to place leather onece 3d printed.
In the video I posted it's what I'm able to do on a flat surface (beginning of the video) but can't achieve on the curved face (I understood it's not possible to extrude curved faces but was wondering if there is a workaround).
Here is what I did on the flat surface :
Message 13 of 22
MRWakefield
Like this?
This was done with the "Emboss" tool.
EDIT:
Or maybe this is better?
Marcus Wakefield
Message 14 of 22
jhackney1972
The process I showed could be reversed.  Instead of offsetting the surface out, you can do it in and when using the Thicken command use Cut instead of Joint.
Message 15 of 22
jeje
Yes exactly that !
I tried the emboss tool but can't select the sketch profiles ?
Message 16 of 22
MRWakefield
I created a new plane and sketch like this:
Then used emboss. Of course, the sketch doesn't need to be a simple rectangle, you could make it a more visually interesting shape if you wanted.
I've attached the f3d so you can see how I did it.
Marcus Wakefield
Message 17 of 22
g-andresen
if you want it to be like @MRWakefield  showed it in his post, you can also do it with a simple extrusion.
günther
Message 18 of 22
jeje
Wow, you guys are amazing !
Thank you all for your great support, much appreciate !!!
Fusion looks to be a great software and his community is just amazing !
Will show you the final result when printed 😉
Message 19 of 22
g-andresen
good luck!
günther
Message 20 of 22
MRWakefield
I'm pleased you got a solution. Was my method not acceptable?
Marcus Wakefield
