can not make visible
Jaeger1787
Jaeger1787
Every element in the browser of the attached file has the  'visibilty' icon 'on'.  However the screen is totally blank.  If I hover the mouse over an element, it briefly becomes visible bu not available for work.
I obviously caught some disastrous key combination which swithed everthig off, but nowhere can I find a corrective action.
dsouzasujay
Hi @Jaeger1787
All you need to do is 'turn on visibility' on the root node.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
jeff_strater
The file you shared actually had all the visibility icons set to "off".  Using "show all components", and "show all bodies" made everything visible:
this is the result:
Jeff Strater
Engineering Director
Jaeger1787
I wonder if there is a SEKE (SingleEntryKeyEntry) that triggers this on/off action and I had accidentally typed it. Problem, was not knowing how to correct it. Thanks guys. Back to normal????
davebYYPCU
Yep,
V
if you have something selected in the browser, and type V for Visibility, it will toggle current state to the reverse.  Very handy, at times.
might help....
