Move cut holes around on stationary body
ddavis177
Message 1 of 9
ddavis177
Is there a way to move the 4 cut holes of the radiation trefoil over slightly on the solid body plate? (image should be attached)
My ignorance made this hard to find a solution to if it is at all possible without redoing the trefoil so apologies if this isn't the place to post this.
Replies (8)
Message 2 of 9
davebYYPCU
Move the sketch anchor point with edit dimension.
Presumes you have followed normal procedures.
Might help.....
Message 3 of 9
jeff_strater
I'm going to go out on a limb here, and guess that this sketch came from an imported SVG.  SVG geometry is "fixed" when imported.  So, you'd need to select the curves from the radiation symbol, choose Fix/Unfix to unfix it, then use Move to move it around the sketch.
Jeff Strater
Engineering Director
Message 4 of 9
TheCADWhisperer
You could also Move the faces.
Attach your file here if you can’t figure it out.
Message 5 of 9
ddavis177
This is my first time using fusion 360 to do anything so as for normal procedures being followed I highly doubt it. lol
But I did create the trefoil myself and didn't import any files for what its worth.
Thanks for the quick replies btw.
To attach the file does it need to be a specific type when exporting?
Again, ignorant on all of this, but it has been fun learning.
Message 6 of 9
TheCADWhisperer
Message 7 of 9
ddavis177
Here you go. Just be ready for a mess I'm sure.
Message 8 of 9
TheCADWhisperer
I would have done differently from the start - but see Attached...
Message 9 of 9
ddavis177
Great, exactly what I needed. Really appreciate the help!
thanks everyone!
watch out for the radioactive cows!
