Can I set a components origin point to match the world coordinate system?
JLD10000
JLD10000
Can I set the origin point of this component to match the world system? Every time I go to move it I am forced to use its original co-ordinate system...
jeff_strater
Create a rigid joint between that component and the global origin
Jeff Strater
Engineering Director
TrippyLighting
Did you insert that mesh into a new component and then move that component?
If not, please describe the workflow you used.
